Dyno Guesses & Bench Racing Forum - Best "Roll Race" Speed/MPH? NON-locking Rear End [Stock LQ4/4L80E 1965 Chevelle]
SIKHS 5
11-27-2011, 01:32 AM
buttoning up my '65 daily driver LQ4 swap, just need need to wire it up, attach a slip yoke and slap the front end back on.
Engine:
Stock LQ4
91 Octane
(Tuned @ 22 Degree Low&High Tables - Sea Level)
Transmission:
Stock Stall(Express Van)
4L80E
Current Rear End:
Stock 10 Bolt
Non-Posi
(well see how long it lasts)
Vehicle:
1965 Chevelle
Malibu Trim
4 Door
10 Fuel Tank Gallon Tank (Weights below are of the original 20 gallon tank[take off about 60lb for the curb weight])
Model: 13669
4-Door Sedan 8-cylinder 283
EST. SHIPPING WEIGHT: 3080LB
EST. CURB WEIGHT: 3240LB
Im hoping to get a Strange S60, Meth. Injection, 12psi KB Racing Turbo Kit, and supporting mods down the road.
Any guesses for 1/4 times as is?
more importantly...
If I'm roll racing what mph starting point would be best/give me the greatest advantage?
thanks!
SIKHS 5
11-28-2011, 10:06 PM
bump...
88blackiroc
11-30-2011, 06:32 AM
Shit ill take a guess. In the fourth I think it can pull 12.6 to 12.9. That's also a pretty low weight. For a all steel four door car at least :). Shit my half not finished interior iroc weights more than ya!
black00ssFL
12-07-2011, 11:35 AM
Personally I don't think you're gonna be going anywhere really fast with the big, heavy, inefficient stock converter from the 80e.
IslandParkRacing
12-07-2011, 01:01 PM
I'm not sure about roll races but without a posi i have a feeling your going to be going nowhere fast...lost of power to 1 tire i dont think youll ever get traction. but with that light weight im sure low 13's
SIKHS 5
12-08-2011, 03:06 AM
how does the 4L80E torque converter differ from the one in a 4L60E? big, heavy, inefficient?
it's around a 1600 stall for what ive been reading.
SIKHS 5
12-08-2011, 03:13 AM
i would be more than happy to be in the low 13s without a locking rear. hopefully high 12's with a strange s60 and a solid gear ratio.
im still wondering the most efficient rpm/mph starting point for a roll race/ the only way ill have to race for a while lol
gs462
12-08-2011, 07:25 AM
I think you;re going to have to drive the car, you want to get it where the trans downshifts for a roll race. I'd guess around 30-40 mph. but all car are different.
black00ssFL
12-08-2011, 08:56 AM
Not even close to each other. The 80e converter is a tank and one of the reason the 80e weighs so much more than a 60e. It's size is the reason for its inefficiency, a smaller aftermarket unit will be more efficient due to better stall, str and due to lighter weight.
The best roll speed will be determined by gear ratio, tire size, and power band of the engine. Like said you're probably just going to have drive it and figure it out. You're gonna wanna be at an rpm level where you are a couple rpm above peak tq, but not so high that you shift right into the next gear at wot.
