Strange 12 Bolt Rearend 33 spline axles detriot truetrac posi
Category: Accessories
Price: $1800
Location (State): UT
Item Condition: Used
LS Engine?: Fits LS Engine
12 Bolt Rear End - Complete - 1993-2002 GM F-Body: Camaro & Firebird
Center Section: Detroit Truetrac - 33 Spline
ABS: 4 Channel ABS - Posi
ABS Reluctor Rings:Yes - 4 channel ABS
Gear Ratio:3.42
Wheel Studs: 12mm x 1.5" Long
Rear Cover Type: Chrome Cover
Rear Brakes: Stock 1998-2002 F-Body Disc Brakes
Brake Line Clamps: Yes - Add Pair of Brake Line Clamps
Sway Bar Install Kit:Install Kit - Black
LCA Relocation Brackets: Install Relocation Brackets
This has been behind a Stock LS1 with bolt ons the whole time other then late last year for 20 miles with roughly 600 hp and only getting on it a couple times from a roll. It has literally seen the track once (while with the bolt on stock ls1). NO gear whine. It is perfect condition. It is black and needs nothing. 1800.00
BTW. This comes with backing plates. If I can find a set of stock rotors and calipers I'll include them as well.
