Twin turbo and e85 guys what wideband for tuning?
As the title says what wideband are you Twin turbo e85 guys using? I want to be able to read both banks. Also does anybody make a wideband specifically for e85 use? Thanks.
You would use the same wide band for E85 that you would use for gasoline. You can tune the same way as you would gasoline... AFR's. There will be people that say you can't, but I would only listen to the ones who have done or actually do it. I personally run E85 and tune just like I would on gasoline.
Or if you want to get technical, you can tune using lambda. Do a search on tuning E85 using lambda.
If you want to monitor both banks... that is simply going to require two sensors.
