96 WS6 12g's in paperwork, trades welcome
Year: 1996
Make: Pontiac
Model: Trans Am
Price: $9000
Mileage: 90000
Private or Dealer Listing: Private Listing
Location (State): NY
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
SUSPENSION;
Eibach Pro-Kit Springs, 1993-1997 LT1 F-body (1.25" Drop Front & 1.25" Drop Rear) $239.99
BMR Bolt-In Adjustable Torque Arm, 1982-2002 F-body $329.95
BMR Lower Control Arms Tubular Chrome Moly Adjustable Street/Track $209.99
BMR Panhard Rod, Adjustable, 1982-2002 F-BodY $134.95
BMR Fabrication Anti-Squat Brackets, Bolt-In, 82-02 F-body $129.95
BMR Strut Tower Brace, 1993-1997 LT1 $ 99.95
BMR Subframe Connectors, Tubular, 1993-2002 F-Body $154.95
BMR Front Sway Bar 32mm Bolt In, 1993-2002 F-Body $189.99
BMR Rear Sway Bar 21mm Bolt In, 1993-2002 F-Body $189.99
Energy Suspension sway bar end links $16
BRAKES;
Power Slot Rotors, 1993-1997 F-body REAR LEFT Rotor $128.06
Power Slot Rotors, 1993-1997 F-body REAR RIGHT Rotor $128.06
Power Slot Rotors, 1993-1997 F-body FRONT LEFT Rotor $ 94.58
Power Slot Rotors, 1993-1997 F-body FRONT RIGHT Rotor $ 94.58
Hawk HPS Performance Brake Pads, 1993 F-body, Front $ 70.99
Hawk HPS Performance Brake Pads, 1993-1997 F-body, Rear $ 61.99
EARLS STAINLESS STEEL BRAKES LINES,
GM Delco Supreme II Brake Fluid, 16 oz bottle $ 7.38
EXHAUST;
Borla Cat-Back Exhaust System, 1993-1995 Single Cat LT1 Camaro/Firebird $859.99
Pacesetter Long Tune "race only" headers
$300
Hooker Off Road Y-Pipe
INTAKE;
K&N Air Filter, 1990-1996 TPI/LT1 Corvette, 1993-1997 LT1 WS6 Ram-Air Package $ 76.99
BBK Power-PlusThrottle Body, Twin 58mm, Camaro/ Firebird, 350/ 5.7L LT1 $329.99 IGNITION;
ACDelco 41-943 PLATINUM SPARK PLUGS
$5.95 ea
Optima Red Top Battery, 800 cold cranking amps, 120 reserve $189.99
MSD 8.5mm Super Conductor Spark Plug Wires, 1993-1997 F-Body, RED $100.10 Auto Meter Triple Pillar Pod, 2-1/16" 1997-2002 Camaro/1993-2002 Firebird $ 58.99
Auto Meter C2 Series, 2 1/16" Electric Trans Temperature 100°-260° F $130.99
Auto Meter C2 Series, 2 1/16" Electric Air Fuel Ratio (Lean-Rich) $ 72.99
ENGINE STUFF;
K&N Performance Gold Oil Filters $ 11
Comp Cams "304" LT1 Camshaft, 210 / 220, .500 / .510 114 LSA $289
Comp Cams Magnum Self-Aligning Roller-Tip Rocker Arms, 3/8" stud, 1.6 Ratio $320
EDELBROCK PERFORMER RPM ALUMINUM CYLINDER HEADS $1,400
TRANSMISSION;
STAGE (2) 4L60E $2,200
7'' Kenwood Touch Screen
Kee Audio Premium speaker kit.
5% tint on all the windows
Shaved door molding, bird emblem
Polished center Panel
I have most of the paperwork to prove the work done too the car. Lookin for a built foxbody or a bolt on LS1 manual car.
