will a 4l60e fit an LT?
Moderator
I'm sure both the 700r4 and the 4l60E were both in the C4 body vet's. I'm kind of confused on your question. I will say that with both transmissions in that car they did use a unique transmission case. If memory serves me correct it has a "V" or a "Y" on the bell housing. The inspection cover is a little different on these units and also the rear of the case is a little different as well. It requires a different tail housing for the torque arm as well. I'm sure a non vet case could be fabricated but the tail housing is the key for one of these units. I have two of them that I snatched off of Ebay if you need one. Just let me know. HTH Vince
