Small Block & Big Block Chevy Specific - SBC in Foxbody?
FowlerMotorsports
11-28-2011, 07:31 PM
I have found a few threads on swapping a SBC in a ford foxbody, but everyone rambles on about different headers and what not. Anyone have a link to do the swap? A step by step guide or something with ALOT of information
Big bird55
11-28-2011, 11:02 PM
hardest thing i found when i was doing mine was the harness. but i was buildign a daily driver. all my friends have ran aje k members with dynatechs. jegs sells a kit with it all
Big Al
11-29-2011, 09:56 AM
The LS series small block is very popular in a fox. Lots of conversion stuff around. Just google it.
Al 95 Z28
FowlerMotorsports
11-29-2011, 06:23 PM
I am doing a 1st gen SBC, I wish I could do an ls swap but I have a engine ready to drop in.
Big Bird, was yours a ls or carbd foxbody?
MikeFSKSpeed
11-29-2011, 07:43 PM
Ive helped alot of my customers with this. AJE covers the K Member, Motor Mounts, Trans Crossmembers and any suspension pieces you need. I stock Kooks headers for the swap but as stated dynatechs work well too. And any SBC performance parts you need, Let me know! we have a huge inventory of most popular brands.
FowlerMotorsports
11-29-2011, 07:52 PM
Thanks Mike, I am actually on the hunt for a camshaft so I will check out your site! I appreciate your help
Big bird55
11-30-2011, 12:18 PM
carbed
FowlerMotorsports
11-30-2011, 05:51 PM
Did you run aftermarket control arms? I hope I can just get me a AJE k-member, headers and do the swap. I plan to make my own trans brace since I am not sure my 700r4 has the same mounts as any other trans. What was the biggest part on converting the driveshaft in order to work? Does a custom shaft need to be made or can you use a GM yoke?
I know the cheapest route is never the best, but what would be a good way to save some cash?
Big bird55
12-01-2011, 06:41 PM
i used the factory a arms. made my own trans brace like you stated. i had a driveshaft made. not gonna chance something like that. but you have to run coil over conversions on your front struts with the aje k member since there is no spring mount on the k member
ss454327
12-01-2011, 06:48 PM
Hit this guy up and see what his setup is. I know him from another forum and he's selling this car for $10k with an enclosed trailer. He ran 9.66 on this pass lifting just after the 1/8 mile. Car has 4.80 gears and won't make it to the end of the 1/4. Needs 4.30s to make it a 1/4 mile car.
http://youtu.be/cEQizF1e77A
FowlerMotorsports
12-02-2011, 06:33 PM
Isn't there a spring mount kit available? or am I looking at the wrong thing? First item
http://www.ajeracing.com/mustang.php
MikeFSKSpeed
12-02-2011, 07:34 PM
That is the spring perch kit you would need. And just so you know, Part # MU-7050 also fits the 700R4!
BTW, when you go to his main page, check out the what speed shop is sandwiched between the Summit and Jegs logo .. ;)
Big bird55
12-02-2011, 10:07 PM
^^ what he said i didnt finish mine i pulled the motor out and sold it i ran coil over conversions on 90/10s on the front
FowlerMotorsports
12-03-2011, 07:52 PM
Clicking that logo goes straight to summit fyi! Might wanna get that checked out lol
MikeFSKSpeed
12-05-2011, 12:26 PM
wow! Im gonna have to make a call.. Thanks!
FowlerMotorsports
12-08-2011, 07:22 PM
Woohoo! Sounds like I should get a discount at S-K Speed! Better yet, give me a list of must have in order to the the swap and we will call it even! :cheers:
FowlerMotorsports
12-19-2011, 09:22 PM
I'd like to bump this as for I still have a great opportunity to own a foxbody at a very cheap price. Any ideas what exactly I will need for the conversion, trying to save the most money at first then upgrade later! I understand k-member, headers, spring perch kit, but what else? Anyone got a run down on everything I need
turbojohnnyb
12-29-2011, 08:27 AM
i am putting a turbo sbc 383 in my 82 mustang and i used all aje parts.
Big bird55
12-29-2011, 10:44 PM
caster camber plates?? drive shaft, tranny member? wiring it up, fuel system? that all i can come up with
FowlerMotorsports
01-12-2012, 05:22 PM
Well looks like this is my cheapest and affordable route I am taking, hopefully picking up the fox body tomorrow! Needs some work but I't will be an awesome little toy for around town.
sbcpowerdfox
01-19-2012, 07:47 PM
i did the 421sbc swap in my 90 coupe using aje k member, tubular lower control arms, qa1 front coilovers, c/c plates & kooks headers, running a powerglide. fit perfect no problems other than the 3 1/2 header collectors are tight to the trans so you will need to run a good fluid cooler.
FowlerMotorsports
01-20-2012, 09:37 PM
Well I have heat shields and heat wraps and will most likely use a 3" collector, what is the best headers to use? are the hugger headers your best option that fit close to the engine/trans? I want to get a set of long tubes and x pipe the exhaust with 3" pipe all the way back
sbcpowerdfox
01-21-2012, 09:41 PM
i have kooks headers, fit great other than close to the trans pan, i see the dyna tech headers use a smaller collector, so i would check them out(cheaper also $$$)
FowlerMotorsports
01-21-2012, 09:54 PM
Well I can get hugger headers for around $250! Problem is knowing if they will be right or not lol but I have several headers to choose from.
FowlerMotorsports
01-21-2012, 09:55 PM
also sbcpowerdfox please post some pics and as many as possible!!!
FowlerMotorsports
02-04-2012, 08:01 PM
Anyone got any good pics on there swap? Still waiting to get my k-member in from AJE!
FowlerMotorsports
02-12-2012, 10:14 PM
Topic has gone dead!!!!! Show some love my chevy mustang friends!!
JUSTINSWS6
02-12-2012, 10:21 PM
Just put a sbc in a 77 ford with a 4l60e tranny was not hard. Lots of wires lol. Yes it can and has been done.
sbcpowerdfox
02-25-2012, 02:31 PM
id have scan all the pics of my swap into my computer(pain in the ass) someday i'll get around to it. but its a pretty straight forward swap, you shouldnt have ant problems
jaywill
03-16-2012, 06:11 AM
http://i261.photobucket.com/albums/ii43/jaywill148/87%20coupe/MUSRATT2.jpg
prerunsilvy11
07-25-2012, 03:37 PM
hey man thx for the info i been thinkin about doin a swap to a 84 stang with a 66 327 sbc and i just got a question the tranny brace that comes with the kit.. wat tranny does it work for?
