NA LS3 Stroker vs. LS7?
Old 11-29-2011, 06:31 PM
halllon's Avatar
Default NA LS3 Stroker vs. LS7?
Hello everyone,
We are a building a LS for drifting and after doing some research it seems we are left with these two options to reach our goal of lightweight, reliable 550-600 rwhp NA horsepower: A stroked LS3 or a LS7. We want to run a wet sump with accusump for cost and are planning on running a semi-race cam, FAST intake, E85, etc.
Which motor would be the most reliable out of a stroked LS3 or a LS7?
How are Brian Crower LS stroker kits rated?
Can the LS3 be safely stroked to more than 427 cubic inches?
Thanks!
Old 11-29-2011, 07:24 PM
3pedals's Avatar
Crower = quality
Old 11-29-2011, 07:34 PM
Orange Juice's Avatar
The ls7 has more bore to work with.
Old 11-29-2011, 08:44 PM
adamantium's Avatar
ls7. A stroker can be just as reliable as any motor but you can't beat the reliability of an all oem motor.
Old 11-29-2011, 09:03 PM
gectek's Avatar
LS3 is less expensive and probably less prone to problems caused by detonation than the LS7 platform was.
I would work with an LS3 416 or 427 and go from there. There are so many big names out there that are less money but the same high quality parts that are readily available through many vendors on here. Most can either build the engine for you or give you the parts to do so yourself.
SDPC gets my vote though. Anything you want, they can get, and if they cant, you probably dont need it!
Just based off of your post though, I am guessing this is going into a non-ls application like a 240/Z/or a few other import bodies, amd I right?
Old 11-30-2011, 10:31 AM
halllon's Avatar
Thanks so much for the input!
You are right, it's going into an import body.
Would the LS3 block need any machining (other than the bore) in order to take the stroker kit?
The LS3 wet sump is a definitive plus as that's what we would go to either way.
Old 12-01-2011, 06:01 AM
What problems with detonation? How does a block cause this? The ls7 is more expensive but the larger bore gives more clearance around the valves and I believe that they have longer sleeves that allows for more stroke with piston stability.
I am not a builder but this was what I found when I researched my build.
Old 12-01-2011, 06:06 AM
djfury05's Avatar
I would definitely use the LS7 for this application.. the longer stroke for the LS3 block to get 427ci isn't worth it especially since you'll be seeing mostly higher rpm's. I don't believe the LS3 can be bored out to 4.125 with the stock liners and thats why it needs longer stroke to make up.
The detonation problems can all be handled in the tune.. Shitty tune and shitty gas = detonation. Its not the block that causes it.
Old 12-01-2011, 06:30 AM
halllon's Avatar
As far as I can see people are safely revving their 4 + inch strokers and that the high rev problems are usually related to the valvetrain. I would almost think the longer stroke of a LS3 427 would be beneficial for us due to the potential of increased torque over a LS7. Additionally, it seems we could build a high compression, stroked 427 LS3 (more power) for below the cost of a LS7. Or am I missing something?
Old 12-01-2011, 07:07 AM
raymond mckinney's Avatar
Go Ls7 if you're looking for 600rwhp N/A. You have more cubes and options and you also have a better choice of Cylinder heads with the Ls7's bore.
Old 12-01-2011, 07:25 AM
godlyxdan's Avatar
This! Just cause in the long run it would be cheaper to start with an LS7 then it would to stroke an LS3 and then go for 600WHP
Old 12-01-2011, 08:41 AM
djfury05's Avatar
The N/A LS7 combo I just purchased made 580 rwhp 545 rwtq thru a 9" and slicks on 93 octane.. stock LS7 heads. Ran 10.32 @ 139mph in an Fbody.. LS7 FTW.
Old 12-01-2011, 02:17 PM
COPO9560's Avatar
You might consider a dry sleeved LS3 block - close to same cost as a LS7 block and far stronger. Larger bores are possible with this route as well.
Old 12-01-2011, 05:49 PM
A sleeved block is another good option.
Old 12-02-2011, 12:34 PM
gectek's Avatar
It does not cause the problems, but it has problems with detonation. If it happens, the LS7 sleeves do not like it, and they have the possibility of cracking the block. With enough searches around here and on corvette forum, you can see what happens. They are not the same material as the LS3.
In reality you can sleeve anything you want or build anything you want. For the power that comes out of them though, for the price, the LS3 block is hard to beat.
The longer sleeve would allow for alot yes. The larger bore is good. Obviously better than the smaller LS3 bore, but if there is no budget you would go with an RHS or Dart block. But, since there is, you could do a 427 LS3 for a really good price and produce a good amount of power. Just check out the dyno forum for some info that is very interesting.
Old 12-02-2011, 10:58 PM
CAMSTER's Avatar
Default Deto-nation
ahhhh, hello? there will be no pre ignition with E85, and the ls7 is the best ever small block from GM, 600 whp N-A no problem.....
Old 12-03-2011, 01:35 AM
gnx7's Avatar
The candle that burns brighter burns half as long.... that being said the higher RPMs you spin it..... the longevity will be compromised. Try to keep it below 7K if you want it to last in a drift environment bouncing off the redline the entire time.
A 427ci motor no matter how you slice it will make a **** ton of torque. With a presumably 4:10 rear which most imports have.... you will have no problem annihilating the tires. It should make 300rwtq off idle and carry 500rwtq to 5K and shortly after that begin to fall off.
Make sure you have a diff cooler so you don't boil that sucker!
I had a 440rwhp LS1 RX-7 with 245's out back, 3.90 gears, it could smoke the tires from the start all the way thru 3rd gear. Those where crappy street tires though. Torque is great!
Old 12-03-2011, 03:00 PM
halllon's Avatar
Thanks guys!
I am coming from single turbo 2JZ's so this will actually be a downgrade in max torque numbers, but the NA drivability of the LS seems very appealing. I reckon we can build a 427 high compression wet sump (accusumped) LS3 for around $15k, whereas the LS7 seems to be about $20k with what we need, and at that point the LS7 seems to be considerably weaker. And, like one of you mentioned, when the LS3 blows we can dry sleeve it if necessary.
This is tough!
Old 12-04-2011, 07:54 AM
halllon's Avatar
Check out this dyno sheet, for instance: http://www.camaro5.com/forums/showthread.php?t=58765
Looks like a good bang for the buck to me.
Old 12-04-2011, 05:06 PM
gectek's Avatar
You do know that those are 2 different things right? Before you try to make fun of what I say, make sure what you are saying is correct.
There CAN be knock with E85 assuming the tuner has no idea what they are doing. There are alot of variables. Building the fuel system a little more inexpensively to run standard pump gas is more budget minded IMO.
I missed the E85 part, but I still stand behind my statement.
Quick Reply: NA LS3 Stroker vs. LS7?
