lq9 build suggestions
Old 11-30-2011, 02:15 PM
+badss+'s Avatar
Default lq9 build suggestions
found a 62k mile lq9 for 1400 is this a okay price? its an 05 engine
long block
Old 11-30-2011, 04:03 PM
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
Yeah that's a pretty good deal id go for it
Old 11-30-2011, 04:43 PM
pairof69s's Avatar
I paid 1400 for an 02 LQ9 with 150,000 but It was also 20min from my house, so I got to check it out before I purchased it. I t was also a complete motor with intake, DBW tb and harness.
Old 11-30-2011, 05:11 PM
+badss+'s Avatar
ok on that note, what should i upgrade before putting it in the car? suggestions welcomed..
Old 11-30-2011, 05:32 PM
if you wanta just put the motor in stock i wouldnt touch anything but imo put a nice cam and heads package together then put it in youll be much happier rather then if you did it in the car no bueno
Old 11-30-2011, 06:07 PM
+badss+'s Avatar
well i was thinking of doing a tsp 233-239 cam on a 112lsa and arp rod bolts,and comp tru union upgrade anything else i should think about. gunna switch my ls6 intake and oil pan from my ls1. probably gunna run a 150 shot for now til i can upgrade to a d1sc next year.
Old 11-30-2011, 06:21 PM
well if your planing on running a FI setup id think you would be better off with a lq4 since the compression is a tad lower just a thought. as far other upgrades id do a timing chain just for peace of mind
Old 12-05-2011, 01:16 PM
OutlawDrifter's Avatar
might as well throw in a high volume oil pump while your at it...i would spend some time checking out different cams. don't forget some new hardened pushrods.
