1981TA
11-30-2011, 07:02 PM
This thread comes from poking through the various NASA car classes and getting brain itch trying to figure out where my car fits best. The car is a modified 1981 Pontiac Trans Am. The closest classes seem to be AI/AIX, ST2 or NXA/B. Can anyone lend insight? The car has the following mods:
Engine: LS1 from 2001 base Corvette (factory stock long block, Edelbrock intake and headers, Holley throttle body EFI),
Transmission: T56 from 1998 Camaro (stock internals, lightweight clutch)
remaining drive train: aluminum drive shaft, 10-bolt POSI 3.23 with disc brakes, DS loop planned.
Front subframe/suspension: Factory frame, with stock sway bars, stock suspension mounting locations, solid motor mounts, Global West A-arms and springs, Wilwood 12" front brakes, and bolt-in subframe connectors.
Wheels/Tires: 16x8 1987 Trans Am GTA wheels with 245/50 Firestone Firehawks for street use. I may go with 18x9.5s and 275s for track.
Weight reduction is considerable: Factory curb weight was 3435 pounds. I estimate it at 3100 now.
Horsepower is around 375 at the wheels and I want to avoid classes where build cost gets very high in order to stay in the pack (I've seen some very high-dollar setups for ST2 here).
