Front Mount Turbo Kit?
Old 11-30-2011, 07:07 PM
Lambert695's Avatar
Default Front Mount Turbo Kit?
I was looking into putting together a front mount turbo on my 98 Trans Am. However, there are so many options! So I was looking into Modular Turbos or Ky-turbo's front mount kits. Does everyone enjoy there KY-turbo setup and about how long did it take for it to be built?
Im looking to be able to make 550rwhp but if I can build my 402 I would like to make more. Is the TC76 turbo a good turbo for the street? Just trying to figure something out for the spring.
Old 11-30-2011, 07:29 PM
Josh@KY-Turbo's Avatar
As of right now 6-8 weeks on a manifold setup. Header setups a bit longer.
TC76 or TC78 is a great turbo for the street. Its is easily capable of 500+rwhp on a stock cube engine. The 408ci is gonna need more turbo.
Old 11-30-2011, 07:58 PM
99Z28LS1's Avatar
1 vote for Josh!
Old 11-30-2011, 08:27 PM
ws602's Avatar
Default Ky turbo twin kit....
KYTP build some bad turbo kits.Call josh he will hook you up.
Attached Thumbnails Front Mount Turbo Kit?-2109169240047301034s600x600q85.jpg-turbo.jpg   Front Mount Turbo Kit?-2865662910047301034s600x600q85.jpg-turbo-5.jpg   Front Mount Turbo Kit?-2463210880047301034s600x600q85.jpg-turbo3.jpg
Old 11-30-2011, 08:54 PM
Ryans99ls1's Avatar
You cannot go wrong with either company. Both offer great customer service. A couple years ago when i first was thinking about going turbo i emailed josh a couple times and he was always great to deal with, even though i never actually bought anything from him. His track record with actual customers speaks for itself, everyone seems to be more than happy. Same goes for modular turbo, i have nothing but positives to say about that company.
also, a 400+ci will need more than a tc76
Old 11-30-2011, 09:00 PM
Lambert695's Avatar
^^^ Ha i dont think I need a setup like that yet!
What type of radiator are people using for these setups?
Old 11-30-2011, 09:02 PM
Lambert695's Avatar
What size turbo do people usually go with? Is ball bearing the best?
Old 12-01-2011, 10:11 AM
Lambert695's Avatar
and also, what is the difference between truck manifolds and C6 manifolds?
Old 12-01-2011, 10:26 AM
O1ws6's Avatar
+1 for josh, he is working on my kit very soon. He is easy to get in touch with and answers all my questions. Just remember you get what you pay for.
Old 12-01-2011, 11:15 AM
ws602's Avatar
cooling set-up...I had Ron Davis make it for me...
Old 12-01-2011, 02:53 PM
1CAMWNDR's Avatar
A C6 manifold on the passenger's side will allow you to keep AC. Still uses a truck manifold on the driver's side facing forward.
Old 12-01-2011, 03:44 PM
Lambert695's Avatar
ohhh so if I want to keep AC then I would buy one of each?
Old 12-01-2011, 04:06 PM
Lambert695's Avatar
and will I be able to keep my factory K-member with Josh's set- up?
Old 12-01-2011, 04:07 PM
jt76's Avatar
I have a KYTP kit i purchased off a member here. I cannot say enough good things about the quality of the kit. The welds and bends are seamless and the overall design is simple and effective. I would recommend it highly.
Old 12-01-2011, 04:15 PM
Lambert695's Avatar
Did you need to install an aftermarket K-Member?
Im just trying to make a list of everything I need to purchase to see the total price.
Old 12-01-2011, 04:44 PM
jt76's Avatar
I bought one, but i had it mocked up with the stock K member. If I were to notch the passenger side for manifold clearance i bet i could have gotten away with using the stocker.
Old 12-01-2011, 05:24 PM
whitesscamaro's Avatar
++1 for Josh@KYTP
Here's some pics of my setup from him. Manifold setup with a Garret GT91 turbo.
Old 12-01-2011, 07:51 PM
in to deep's Avatar
with the modular kit you dont have to cut the radiator support .buy a new radiator or new fans and its only 799.id say the modular kit.
Old 12-01-2011, 07:53 PM
Ryans99ls1's Avatar
I wouldnt go below an 80mm turbo on a 400ci engine but i am by no means an expert. Call up a sponsor and pick their brain. You dont really need ball bearings, theyre nice but not really necessary on a V8
Old 12-01-2011, 09:50 PM
Lambert695's Avatar
Josh's work looks amazing!!! what is better, the manifold kit? or have him make those custom headers?
Quick Reply: Front Mount Turbo Kit?
