should i replace oil pump during cam install
getting ready to install my trex cam My car has 84000 miles on it. is it necessary to change the oil pump? i am going to be getting a new timing chain from my local auto parts store. thanks for the help
how much are the oil pumps and where can yu get them
I would probably leave the oil pump alone as 01 cars aren't know for oil pump failures. Likewise with 84,000 miles on it even if the car was a 98 or 99 I'd leave it alone. Most of the cars with oil pump failure had less than 35,000 miles on them.
Many of the sponsors sell a ported oil pump I think ~$120 to $150 is typical. Local GM dealer sales a LS6 for ~$85
My Katech ported LS1 oil pump was $109 about 18 months ago.
You should change the oil pump on a 98 if you are going to be in there. They are around 100 bucks for an LS6 type. If you do a timing chain swap (and you should, so do a double roller set up, only around 80-90 bucks from various sponsors) you have to remove the oil pump to do it. The o-ring is on the oil pick up tube that extends down into the oil pan. This is a two dollar part from your local GM dealer that could save you having to pull apart the front of your engine again. There is a certain way it needs to be installed or else it gets pinched and you will lose oil pressure. Do a search on o-rings and you will find it. I did after my o-ring disaster. Good luck and have fun with the extra power.
