Best Priced ADJ RR's
Old 03-13-2004, 01:58 PM
BBADWS6's Avatar
Default Best Priced ADJ RR's
Im looking into putting some RR's on my car, they will have to be 1.7s. I havent dont much shoping around so i figured i would ask all of you. They will have to be adjustable, so i can set my lifter pre load.
What do you guys sugggest.
Old 03-13-2004, 02:21 PM
30th TA 0219's Avatar
The Patriots, when they come out, I believe?
Old 03-13-2004, 06:16 PM
SPANKY LS1's Avatar
All available adjustables are $700-$900+ right now. As said. Patriot is supposedly coming out with them, and I'm sure that they will be up there, quality and longevity wise, with Patriots other offerings (heads, springs, valves, and seals).
Shawn
Old 03-13-2004, 07:00 PM
BurnOut's Avatar
What about the Comp Pro Magnums?? IIRC, they run about $450.
Old 03-13-2004, 08:38 PM
SPANKY LS1's Avatar
The Comp Pro Magnums are not 1.7s, they are available in 1.75 & 1.85.
Shawn
Old 03-14-2004, 02:05 AM
Spinmonster's Avatar
crane's 1.8's are also available in 1.7 and weigh less than the yella terras and are fully adjustable. They fit under the stock covers. I had them. They are also marketed under the VHP name for 639 with guidplates and hardened pushrods.
Old 03-14-2004, 01:26 PM
BBADWS6's Avatar
Yea i wish the comps were made in 1.7, i would definatley go with them. Thanks for all the info, time to go make some money!
