Tools & Fabrication - Looking for the little bits for a collector
projektnitemare13
12-01-2011, 02:09 PM
I need to find the little metal pieces that go in between the 4 pipes that go into a collector. Or a lead to someone that can make em. I have 1-3/4" pipes. thanks.
Twin_Turbo
12-01-2011, 07:18 PM
Why not make them yourself? All you need is a section of the pipe you have, cut triangular shaes out the end. Easiest is to cut a short section of pipe, cut it lengthwise in 4 equal aprts, trim these 4 to a pointy/triangular shape and then trim the bottom part so that you can make a piramid out of the 4 sections that fits flat on the pipes. It's kinda hard to explain but you'll have to fishmouth the ends a bit.
projektnitemare13
12-01-2011, 07:24 PM
Yeah im gonna give it the old college try (10 minutes of trying, followed by a six pack...followed by banging on it til it works :P) but Yeah I'm going to look into it, either that or ill use a flat piece, its for a set of turbo headers, so it might not actually make a huge difference, but, ill give it a try.
HighspeedLean
12-04-2011, 08:58 AM
So you mean these?
http://www.spdexhaust.com/pdfs/12-13_Form_Collectors.pdf
projektnitemare13
12-04-2011, 09:11 AM
YES thank you, kept looking for those damned things.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
