Any "better" year 5.3's for FI?
Just wondering if there are any advantages to using a certain year 5.3 for FI. Does it matter at all i.e. better heads/rods/pistons over a different year? Or are they pretty much all the same?
TIA
TIA
The 04+ ones are probably better due to the rods. I'm not exactly sure when they changed them but I think late 04. I'm using a gen3 block with the gen 4(floating pin) rods and pistons. Mines a 4.8 though.
another thing to add would be that the 07+ 5.3s come with 799/243 heads and that would make them a bettter engine. The fastest stock shortblock car has an aluminum 5.3(l33)with 799/243 heads and has run 8.65@167iirc.
I dont think you will have a problem with any 5.3 you decide to go with. As long as you get a healthy engine and have a spot on tune it should do fine.
Im building a stock shortblock 4.8 setup and plan on making 650whp on pump gas and 750ish on race gas. Unless i decide to go with e85 then probably closer to the 750 all the time.
cant go wrong with the 2005 l33 motor, flat top pistons, 10.1 compression, ls6 heads....ls2 timing chain, has the bosses for the timing damper also, and has a special cam..
At 10:1 compression will you have to swap to a larger combustion chamber head to lower the compression before going turbo? I thought the iron 5.3L had 9.5:1 or 9:1 compression ratios.
Yes, hoping to drop 150lbs and pick up 100rwhp. It ran 10.45 with the 6.0 setup that was under turbo'd. This should get me in the 9's with a very budget friendly combo. The Nova is my advertising so thats the reasoning for the budget setup this time, lots of guys looking to do similiar builds but cant spend $4000 on a shortblock.
