cams prolly not ideal... but will it work ok?
232/238 595/605 114
15-16 lbs through a D1sc 370.
4l80e
Not sure on rear gear or stall yet what would you suggest? Thanks
4l80e
I'm sure it'll work fine. If it doesn't work the best, it wont cost you anything to keep it in and swap out later....If you swap out before you even find out if that works well or not you could be throwing more money away.
my cam is similar to that and works awesome on my turbo car
LS1Tech Sponsor
For the gear and stall what do you plan on doing with the car, are you running 26 or 28 inch tall tires and how high to you want to see the rpm through the traps? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I wanna don't wanna exceed 6700 rpm really and not sure on tire size yet i havent calculated anything up cause I'm not to good at it lol I've been told to run a 26 inch tire but never told the benefit of doing it. Car will be street driven on nice days and at the track every other weekend.
LS1Tech Sponsor
Sorry, I was on a backhoe all day. What a muddy mess...
26 inch tall tires will shock the tread surface really hard and they tend to then go up in smoke. 28 inch tall tires have a taller sidewall and they don't shock the tread surface as hard. The taller sidewall absorbs more of the initial hit. Hopefully this makes sense, it has been a long weekend for me.
I'd go with 28 inch tires, a 3200-3500 rpm stall converter, and 370 through 390 gears. Bob
__________________
LS1Tech Sponsor
Thanks Joe, I appreciate it. Bob
__________________
