LS1 parts needed!
LS1 parts needed!
Things i need-
98-02 F-body rack and pinion
98-02 F-body steering knuckle
LS1 oil pan
LS1 water pump
241,243,317 etc. heads
All pulleys
LS6 intake
Valve covers
Coil packs and brackets
wiring harness and computer
Long tubes and y-pipe
Pretty much everything except a short block..
You can text me ( 303-532-6258 ) or send me a PM
Thanks
LS1 oil pan
LS1 water pump
All pulleys
LS6 intake
Valve covers
Thanks
I have some valve covers, but I think they are perimeter bolt. If that will work, I'll go look. email is mpaolino@att.net
I have a steering knuckle/shaft from a 98 Z28. I can do $35 shipped to you.
My paypal is wcr621@aol.com
I also have the whole column as well if you should need one.
