2000 Trans Am 6spd built
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $9000
Mileage: 110000
Private or Dealer Listing: Private Listing
Location (State): PA
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
6-Speed, LS1 BUILT. 110,000 miles.
T-tops, Black Leather Interior, Power Everything.
New Optima Redtop Battery, New 245/45/17" Firehawk Front Tires New headlights, New fuel filter, New Front Brakes, New MAP Sensor, New 02 Sensors.
MODIFICATIONS:
-LS7 Clutch
-LS2 Flywheel
-LS6 Oil Pump
-ls6 Rockers
- LS2 Timing Chain
-LS6 Heads
-Texas Speed's Torquer 2 CamShaft 232.234/595.598
-410 Gears
-BBK 80mm Throttle Body
-QTP Long Tue Headers, No Cats (Have stock ones if needed)
-SLP Y-Pipe
- Magnaflow Catback Exhaust
-K&N Cold Air Intake
-B&M Short Throw Shifter
-LS7 Plug Wires
-Sub Frame Connectors
-Koni Yellow Adjustable Shocks
-17" American Torque Thrust 2 Polished Aluminum Wheels
-HP Hawk Performance Brake Pads
- Drilled & Slotted Rotor
Car was Tuned By Sarver Performance & Dyno'd by Street Lethal Performance at Over 400 whp
The build was done at 80k miles.
-2nd gear syncro is wearing. Shifts fine unless high in rpms.
-Could use a new drivers side headlight bracket (which may be fixed soon)
-Drivers side seat is starting to tear in the normal place on the side
I've lowered my price due to the syncro, to $9000. I'm pretty firm.
Email me at downtheroadgrafix@yahoo.com or call (412) 403-9941 Serious buyers only!!!!
