What other cars have the same lug pattern
Old 12-02-2011, 10:18 PM
btownws6's Avatar
Default What other cars have the same lug pattern
What other kinds of cars have the same lug pattern as the 4th gen trans am? just curious bc i know how vw and bentley are the same and what not so was curious whose rims fit on my car?
Old 12-02-2011, 10:30 PM
xX-Z28-Xx's Avatar
Subscribing
Old 12-02-2011, 10:35 PM
QIK E's Avatar
It's a 5x4.75 bolt pattern. 5x120mm wheels fit too although others will disagree ...Sooooo S10s, corvettes, bmws, others
Old 12-05-2011, 10:38 PM
btownws6's Avatar
why do they disagree?
Old 12-06-2011, 01:06 PM
Spd-Kilz's Avatar
4.75" = 120.65mm
BMW etc. wheels = 120.00mm
They do fit, but the disagreement is whether or not you should do it. Technically it is the incorrect size.
Old 12-06-2011, 01:46 PM
TruBloodTransAm's Avatar
There's a guy on here who put on BMW wheels. Search for it.
Old 12-06-2011, 03:31 PM
QIK E's Avatar
There's a ton of people that run BMW wheels....search for my thread on 5x120 wheels
Old 12-07-2011, 01:06 PM
SSCamaro99_3's Avatar
People do it (5x120). However you are pinching all of the lugs towards the middle of the pattern. There will be forces exerted on them that they are not designed for. It is very small, most likely inconsequential, and you will probably not experience a problem. I wouldn't do it on my car.
Old 12-07-2011, 01:30 PM
Sladester2's Avatar
subbing
Old 12-08-2011, 12:52 AM
meine96ws6's Avatar
I have ran 3 different 120mm wheels and never had an issue.
I didn't exaclty baby the car either.
Old 12-08-2011, 12:09 PM
~ReapeR~'s Avatar
GTO wheels fit. I have a set on my Z28. I had to grind the hubs out a little, but no vibrations and they sit flush on the hub.
Old 12-08-2011, 12:11 PM
~ReapeR~'s Avatar
Old 12-08-2011, 11:30 PM
dodge69874's Avatar
This website will tell you.
http://www.roadkillcustoms.com/hot-r...e-Database.asp
Also, I think qcon had some BMW wheels.
Old 12-08-2011, 11:37 PM
cemlsx's Avatar
I have 19` bmw wheels on my Firebird , and I dont baby the little V6 either ..
No problems so far .
Old 12-08-2011, 11:42 PM
PurpleZL1's Avatar
CTS wheels! 2008 or newer. Check out my pics.
Old 12-10-2011, 10:48 AM
btownws6's Avatar
thanks guys im just thinking for looks not track use. has anyone had any bad experiences with those kid of wheels?
Old 12-10-2011, 11:16 AM
whytryz28's Avatar
So many people run BMW wheels with no issue, infact ive never heard of any issue with those wheels.
Old 12-11-2011, 04:22 PM
2QuikTA's Avatar
I run Ruff's with BMW specs, no problems.
Old 12-11-2011, 06:47 PM
PGUFF's Avatar
Me too, and no problems so far.
Old 12-11-2011, 07:27 PM
NVR_SPDS's Avatar
I ran some Sportmax 006s on my car for a while. They were 120mm and not a single issue. Only reason i changed em, is because I needed something wider.
Quick Reply: What other cars have the same lug pattern
