ws6 ram air question
Old 12-04-2011, 12:25 PM
Jake18's Avatar
Default ws6 ram air question
On my ram air hood there are piece(s) of black plastic inside the scoops. How do I remove them? I just want the outside air going straight into the lid. Thanks
Old 12-04-2011, 12:32 PM
00'WS6Rocket's Avatar
I drilled mine out with air drill
Old 12-04-2011, 01:19 PM
Blasko's Avatar
The bottom of the hood has some rivets you have to drill out and then you can remove the baffles.
Search for debaffle hood and you should find a good many posts on this.
Old 12-04-2011, 03:20 PM
Jake18's Avatar
alright thanks for the help
Old 12-04-2011, 05:37 PM
71novaguy's Avatar
i took out the rear ones but left the front. I would think the ones in the back provide the most restriction since they go back up. I figured keeping the front baffels would help deflect water.
Old 12-04-2011, 06:55 PM
Jake18's Avatar
worked perfectly. i ended up taking all the plastic pieces out. i read on here that if i have a k&n filter it soaks up water pretty good. i hardly ever drive my t/a in the rain anyway
Old 12-04-2011, 10:53 PM
Ronny_02_WS6's Avatar
I just removed two of the Plastic baffles with a flathead screwdriver and a hammer, I just hammered the screwdriver to the little nail heads from the ram air till they fell off.
