TImmy_Jones
12-04-2011, 02:35 PM
So I drive the car today to the gym and then to get gas, pull up at the pump and ill it up with 93. Get in car, go to start it, and it just makes a 'Click' noise, it will not turn over. I try a few times and cannot get it to turn over. I figure what the hell and try and jump start it (in a real tight space, by myself) to no avail. So I push it into a parking spot and try one more time....starts fine. I drive home, no SES lights, everything looks great (volts, oil pressure). I park it and start it again, no problems.
Would you be concerned? Anything I can check? Could it be a dead spot?
Car always starts fine, everyday. I am thinking when I tried to bump start it, probably just moved the flywheel a little bit and now it starts fine.
