Th350/400 guys what gears you running steer/strip????
Old 12-04-2011, 06:00 PM
Pete91's Avatar
Default Th350/400 guys what gears you running steer/strip????
Okay so I'm ditching my 6 speed in favor of a built th350 RMVB trans brake ect. It has a ptc3600 nitrous converter also. I was thinking of like 3:23's as I like to roll race and drive my car a lot on the street pretty far distances. I have 4:46's now I know they have to go. When I got my 12 bolt it cam with 3:73's I was thinking of using them but just think that will be to much rpm wise. I have never had an auto car stalled before and I'm just wondering what to expect when driving around town and cruising on the highway any input would be much apreciated.
Old 12-04-2011, 07:14 PM
los p's Avatar
i have 373s, the same exact converter with a th400 and a 28 inch tall tire. its not bad to me i do around 2800-2900 at about 65 so i keep it around there when im cruising.
Old 12-04-2011, 07:24 PM
ohioz's Avatar
I have 3.23s with my th400 and a 28 inch tall tire, I tach 2800 at 70
Old 12-06-2011, 01:59 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running 4.11s with a 28" tire
Old 12-24-2011, 11:01 PM
yoshgixxer's Avatar
3.55's 28"tire 3000rpms at 65.. 4k stall... probably would be alot better if i didnt have such a high stall.. but it is a blast to punch it and bang it down into second on the highway at like 60mph
Old 12-25-2011, 08:10 AM
Cam72aro's Avatar
If you drive the car a lot then a th350 is not the way to go. Do an auto with overdrive. Your motor will thank you later.
Old 12-29-2011, 12:35 AM
Wicked94Z's Avatar
4.71 go big or go home. 1/8 mile car, i turn 3500 at ~55 mph. Just because it's loud doesn't mean its bad for the motor, get real.
Old 01-01-2012, 06:59 PM
Cam72aro's Avatar
Hmmmm yeah right buddy. Just finished my 80e swap and car turn 2200 rpms at 65. Rpms for a long period of time put excessive heat in a motor and wear. I bet my motor last 3 times as long as yours, you get real man.
Old 01-02-2012, 03:12 PM
screamnbird01's Avatar
i have a ace racing transmission turbo 400 with a 3800 nitrous stall and 3.42 gears and on 17in z06 rims with 275 40 17s at 2700 im at 60mph
