gt45-y2004k turbo?
Old 12-04-2011, 07:58 PM
boosteddragon's Avatar
Default gt45-y2004k turbo?
fwhp/street driveability/track manor
Engine info:/lt1 383 9:1 comp/ 91 pump gas for street/c16 for track/
Drivetrain info: th400/10-bolt 3.42
Specs for turbo:twin gt45 y2004k
Compressor Size: Inlet = 4 3/16", Inducer = 68.7MM, Exducer = 97.8 MM, Trim = 69,A/R = 0.66, Intake (ID / OD) = 2.25" / 3.25"
Turbine: Outlet = 4", Turbo flange = T4, Downpipe flange = 3.5" V-band, Inducer = 87.4 MM, Exducer = 77 MM,Trim = 92, A/R = 1.05
GUY'S GIVE INFO SOME SERIOUS INFO
Old 12-04-2011, 08:37 PM
lsxmalibu's Avatar
Im thinking your going to hear crickets, its a chinese turbo and will get no love in here...but I run one and its a nice unit....Not sure of your motor, but on my 5.3, 10psi with 3.42 gears it runs mid 10's
Old 12-05-2011, 04:34 PM
LOL yeah I should of known,these guys are ruff if your not down with there crew or not buying named brand...hahahahha thanks lsxmalibu.. I guess i'll take my answer to yellowbullet
Old 12-05-2011, 05:29 PM
LS1NOVA's Avatar
I ran a Master Power GT45 (same specs as the Ebay unit) on a 6.0 LS. Made 600rw on 14lbs and was a beast on the street. Ran 10.70 in a 3400lb Nova with limited traction. Turned it up to 17 and did 10.45 at 132. I think you will be happy with it.
Old 12-05-2011, 08:13 PM
Thank you also LS1NOVA.
Old 12-05-2011, 08:54 PM
Parasoth's Avatar
Some magazine put two on a 4.8L and made around 50 dyno pulls at 1000+ HP, never broke a sweat.
These little things are gems.
Old 12-06-2011, 07:09 AM
lsxmalibu's Avatar
not the same turbo...but if you go here...theturboforums....lots of posts about the y2004k
Old 12-06-2011, 03:42 PM
theturboforums
Old 12-06-2011, 03:43 PM
Niiiiice im do some more soul searching..lol thanks parasoth
Old 12-06-2011, 07:07 PM
ponjohn's Avatar
Ls1nova...did you run a single or twins?
Old 12-06-2011, 07:13 PM
LS1NOVA's Avatar
single. Crap, two would have been ridiculous!
Old 12-06-2011, 09:51 PM
RealQuick's Avatar
One is way too small for 383ci... two of them are a different story
Old 12-06-2011, 10:51 PM
1_Bad_82ttCamaro's Avatar
Great turbo, I personally have not used one yet , but I have seen them used on buddys builds and they make good power and they have had no problems so far.
I think the exhaust housing AR is to big for 2 ebay gt45s but I may be wrong.
Old 12-07-2011, 07:27 AM
LS1NOVA's Avatar
Look at the specs of the original post. Its a little small as a single for a 383 but not WAY too small. There is two different turbos being talked about in this thread. The one the OP is asking about has a smallish compressor wheel (68mm) but has a pretty hefty turbine (77mm) with a 1.05 AR. Better have a good 383 to run two of those.
I would work great as a 600-650rwhp setup as a single. Anymore than that and look elsewhere.
Old 12-07-2011, 07:39 AM
RealQuick's Avatar
68mm turbo is way small for 383ci V8. That turbo may make great power up to 600-650rwhp, but would probably crap itself after that. Turbine side is fine IMO, but that compressor wheel is tiny.
OP - what are your goals for the car?
Old 12-07-2011, 08:05 AM
LS1NOVA's Avatar
Ok I guess the OP edited his original post to say twin GT45's. Thats going to make a crap load of power. I guess the goals are pretty high. There was a silver Chevelle from MN making around 1400 hp on a BB with two.
Old 12-07-2011, 10:15 AM
ponjohn's Avatar
I think two GT35's are a better choice...no?
My nephew has one gt35 on a worked Evo and it makes a ton of power.
Old 12-07-2011, 11:35 AM
Sarg's Avatar
Going to be running twin 70mm .82 AR on my 5.3...just depends on what you want to do and what kind of boost.
Old 06-01-2012, 02:15 PM
468BIGBLOCK's Avatar
would two ebay gt45 turbos work well on a lq4 6.0??
Old 06-01-2012, 02:55 PM
TheLS1Lover's Avatar
So basically your looking at twin T4 70mm Turbos with 87mm Turbines. It will work, but may take longer than you would like to spool. I say run em'! Denmah uses one from VS Racing and is at 20lbs boost.
Quick Reply: gt45-y2004k turbo?
