Slips when warm (4l60e)
Old 12-05-2011, 12:45 AM
Ls1Rook's Avatar
Default Slips when warm (4l60e)
Starts to slip in about 5 minutes of driving, then it feels like if it locks up and unlocks around 45mph, after that all gears start slipping, the longer i drive it the more it slips.
After letting it cool down everything works fine??
Do i need a rebuilt or could it be my converter?
Old 12-05-2011, 04:55 AM
wav3form's Avatar
Have you tried changing your fluid? Do you have the correct fluid? If the fluid is thinning out as it gets hotter, that may be the problem - my dad has this happening in his Lincoln LS because the factory supposedly put the wrong type of trans fluid in the cars. There's a TSB for it. Maybe something similar is going on with you.
Old 12-05-2011, 10:49 PM
Ls1Rook's Avatar
Will be changing it in a couple of days, do you know if it has any kind of filter I can change while im at it?
Old 12-06-2011, 07:57 AM
lt1pwr1's Avatar
There is a filter on the 60e. Honestly, I hate to say this but I bet when you drain the fluid you'll see a bunch of clutch material. The fluid is relatively cheap to change out so you can try it but most likely you need a rebuild. How many miles on the trans?
Old 12-06-2011, 03:51 PM
Gilbert@Ace Racing's Avatar
Unfortunately if it is slipping then it will have some internal damage. Call me and I'll walk you through a few steps and help you understand what's going on.
g
Old 01-01-2012, 03:18 PM
Ls1Rook's Avatar
Changed oil and filter and everything is back to normal, Thanks guys.
Old 01-05-2012, 05:09 AM
rpg020390's Avatar
wow you are very lucky!!!!
Quick Reply: Slips when warm (4l60e)
