Take a look at these plugs. ATVracer & ShiznittyZ28 I want your input.
Old 12-05-2011, 08:50 AM
armyboyatc's Avatar
Default Take a look at these plugs. ATVracer & ShiznittyZ28 I want your input.
I have a bolt on LS1. LS6 intake, P&P TB, Granatelli MAF, SLP lid, LT headers, TSP true Dual exhaust, UDP, 6 speed, 4.10 gears, Stock injectors. Full Dyno tune.
We went out this weekend and tuned it for the kit. I am running a 150 shot through a NOS single fogger nozzle. The pills are a 63 N and 38 F. The pictures are of a NGK 7 at 18 degrees of timing. We pulled out 10 degrees of timing for the kit. After this pass shown we pulled another 2 degrees out of it after this pull which gave us a grand total of 12 degrees pulled for the kit.
What do you think about it?
It seems to me that I need to step up the fuel jet one or two.
Old 12-05-2011, 08:54 AM
Ryan@RPM-Motorsports's Avatar
Did you drive it back to the pits?
Old 12-05-2011, 08:57 AM
10secZ28's Avatar
Im his friend Ryan, no this was killed at wot at the top of 4th
Old 12-05-2011, 09:06 AM
armyboyatc's Avatar
Brandon? LOL.
We did the runs on the highway. 3rd to 4th gear pulls. I had no traction in second.
Old 12-05-2011, 10:16 AM
fergymoto's Avatar
Need to see way down inside, down to where the porcelain ends
Old 12-05-2011, 10:41 AM
SSPerformance's Avatar
Yea cut the threads off so we can see
Old 12-05-2011, 11:24 AM
ShiznityZ28's Avatar
Ill take a look when i get home DOD blocks pics... or you can email me Steve@glenburnieracing.com
Old 12-05-2011, 11:35 AM
armyboyatc's Avatar
Let me cut the threads off and that way you can have everything you need to check it out.
Old 12-05-2011, 12:00 PM
ok. but also keep the top. the top has more info than most know....
Old 12-05-2011, 12:07 PM
Phantom's Avatar
That's a pretty hot plug timing wise
Old 12-05-2011, 12:18 PM
10secZ28's Avatar
What would you recommend doing?
Old 12-05-2011, 03:54 PM
armyboyatc's Avatar
Here is the plug cut open. I dont see much of a fuel ring at all. MAYBE just a hint where the porcelin flares out but thats it.
Old 12-05-2011, 04:03 PM
Phantom's Avatar
Doesn't look too bad. A little fuel ring, but nothin much. Looks pretty good on the fuel. May be able to lean it out a little. I would definitely pull a couple * if it was me though.
Old 12-05-2011, 04:11 PM
Phantom's Avatar
You probably don't have a vacuum gauge, but if you do, pull the timing out and see if it picks up any vacuum down track. MPH will tell the tale as well.
After taking another look, the pictures aren't great, but that timing mark may not be too bad. My eyes play tricks on me. the timing mark is either out at the end of tip(where mine usually ends up) or back at the bottom of the bend. There's no set place on the strap the mark should be, you can add or subtract and watch the mph. If the mark is out at the end, you might add a * and see if your mph increases, then see where the mark is. It may take some more. If mph decreases after the change, obviously put it back.
If that mark is back the bend where I originally thought, I would definitely pull a couple out. Just my opinion of course. I hope the pro's chime in to back me up or tell you don't listen to me and "this" is what you should do instead lol. Good luck
Old 12-05-2011, 04:26 PM
10secZ28's Avatar
I want to take a stab at this.......fuel looks real close but back off 2-3 degrees of timing becsuse the heat looks to be in the bend. But of course I want to hear from the pros as well
Old 12-05-2011, 05:07 PM
camscam02's Avatar
cold and no timing
Old 12-05-2011, 05:18 PM
10secZ28's Avatar
Cam im curious to know what your seeing
Old 12-05-2011, 05:22 PM
10secZ28's Avatar
Is what im seeing the cadian starting to burn off when in fact its not the timing mark at all?
Old 12-05-2011, 06:00 PM
camscam02's Avatar
this will help explain it better than I can. yes the cad is burning off but still no heat in it yet.
"An NGK strap, will not really get the purple ring that an Autolite does. The first thing you see on an NGK, is that the cad is sort of just bubbled up and ashey looking, with maybe a goldish tint. A wipe with your finger will clean the strap right off. This is NO heat and usually very safe. When you start getting heat in an NGK, you WILL see it. The strap will obviously get darker, startting at the end and moving toward the bend. The color will be a dark brown, or even black looking, but will be easily seen. If you are having trouble seeing heat in an NGK plug, you probably don't have any"
Old 12-05-2011, 06:08 PM
ATVracr's Avatar
Originally Posted by camscam02
cold and no timing
This ^^
Also doesnt look like it has been run long enough to color the plug very good.
it will start to burn off the chalk color on the strap when you get some heat in it.
Quick Reply: Take a look at these plugs. ATVracer & ShiznittyZ28 I want your input.
