View Full Version : Mount flipping
bonestockgxp
12-05-2011, 04:56 PM
I'm looking for info on flipping my motor mounts, witch ones what good dose it do
08 GXP
gxp-miller-gxp
12-05-2011, 11:14 PM
should search for it, there is a write up somewhere
its the top one
when you open the hood you will see the black brace connecting the frame of the car to a dogbone that then connects to the aluminum bracket that is connected to the engine.
-inside the black brace connecting to the car is the square motor mount. flip it. now instead of the engine moving by itself it will move more with the car. you can notice the diffrence and its a free mod. i like it. and there are no cons
bonestockgxp
12-06-2011, 02:59 AM
Wtf.... What's the trick to getting the rubber out without cutting it out
gxp-miller-gxp
12-06-2011, 05:38 PM
detach the dogbone from the square mount.
leave the axle inside the mount and put the bolts on each side of it back on the axle and tighten them really tight. spray tons of wd-40 all over the mount so it will slide over. then get a wrench on both sides and push or pull till it flips
Mels SS
12-06-2011, 07:32 PM
Dont flip it replace it. Thats the best thing to do.
http://www.3800performance.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=3800P&Product_Code=MSP-MM
xxtheshockerxx
12-06-2011, 08:56 PM
x2 works great
bonestockgxp
12-07-2011, 05:05 AM
Right I'm waiting on a buddy to buy the 2 pack of mounts but in the mean time imma flip it. Now when I replace it I'm guessing I'm going to cut the old one out, how hard is putting the new one in?
rm08gxp
12-07-2011, 08:39 AM
Curious to see how much a difference can be felt between a flipped mount, and a poly?
Mels SS
12-07-2011, 08:44 AM
Very easy to do this mod and you can feel a big difference.
