LQ4 PowerSteering Pump Fitting Size
i was wondering what the fitting size was on Pressure port on the back of the stock power steering pump(LQ4), is it a O-Ring seal? thank you
I looked last night and that is the one I thought it was but am not 100%. If i was in your position I would probably order it expecting it to work and if not summit is good about returns. The only other one it could be that I saw was the 18x
