Tr224 + Ls6 Springs
We just went this this subject (again) recently. LS6 springs are marginal even on an LS6 stock cam and are dead wrong for an aftermarket cam.
https://ls1tech.com/forums/generatio...w-springs.html
LSX Mechanic
To clear things up, the yellow LS6 springs found on the LS2/3 engines are rated to .570 lift. I've ran them before on a softer lobe .540 Cam Motion cam with no problems. Anything over .550 is going to be iffy depending on the aggression of the profile, and valve springs really aren't something you want to gamble on.
Do yourself a favor and buy the PSI 1511 Maxlife springs. They're the best beehive spring on the market, cheaper than PAC 1518's, and have a 0% failure rate. On a low lift cam like the TR224, you could run the PSI's for 100,000 miles without any issues assuming correct pushrod length was measured/installed.
They might have a low failure rate but I promise you its not zero!
