Safe bore size 5.3
Safe bore size 5.3
I was wondering if anyone has found the safe bore limit for the gen 3 iron block 5.3?
I know the ls1 is 3.905/3.908 but I haven't seen the 5.3 specs. Was wondering if it was possible to bore it out to 4.000 plus safely wanting to run a LS3 internals
LS1Tech Premium Sponsor
Safe is the LS1 spec, as mentioned above, at 3.90x".
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
i have punched mine to 3.905 and still have almost .200 left all the way around in the holes
putting together a 395/6 so i am testing waters people say cant be done and im checking everything twice
but yes a 3.905 is no problem
I punch mine out to the exact 3.898 bore spec of the LS1 piston. I was at minimum wall thickness for cylinders 2 and 6, so be careful. Sonic test before boring blindly to piston size.
