Corvette Performance - low,surging idle
99hardtopc5
03-14-2004, 12:37 AM
i just installed an ls1 hotcam that a friend gave me in my 99 c5, sounds great at idle but tends to surge and idle low almost to the point of dying.
wandering if drilling a hole in the throttle blade will help? i am a little low on funding so ls1 edit and dyno tuning are not an option yet. it is a 6 speed car and everything else is stock.
Carbon
03-14-2004, 01:13 AM
drilling a hole in your tb will help out. a buddy of mine drilled mine out .25" and it helped out alot as far as surging goes
99hardtopc5
03-15-2004, 12:15 PM
researched rilling the throttle blade, it is not advised because of the elctronic throttle control system,looks like i have to get it retuned
GA_Driver
08-21-2004, 09:18 PM
What is the correct RPM for idle? I have am 01 C5... @ idle, it sits at 500, but sometimes when shifting from park to reverse, or from reverse to drive, it drops below that and seems to bog for a second.
It doesn't do it at any other time. Should this be a concern? I'm bone stock, BTW.
99C5JA
08-23-2004, 01:15 PM
The idle needs to be tuned. The decay and idle values sound like they need to be changed. And 500 seems very low GA_Driver. My idle is set at 850. Stock was around there iirc. I would think an A4 car would idle about 800-1000.
GA_Driver
08-24-2004, 09:53 AM
So I need to go ahead & get the HPtuner, then. Or maybe check for a frog stuck in the fuel filter. :D
99C5JA
08-24-2004, 11:11 AM
GA_Driver check with another A4 driver. That may be normal. A friend of mine with an A4 Fbody says his idle was around there stock. I would have thought an A4 would idle higher than an M6, but I've never owned one or paid attention to the ones I've ridden in. You're probably fine.
GA_Driver
08-24-2004, 11:42 AM
I'll hit corvetteforum (ugh) and see what Search turns up. And thanks for replying, I appreciate it!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
