Dyno Guesses & Bench Racing Forum - Cammed bolt-on 08 C6Z06 vs built 2002 Camaro with 402ci
odarabla
12-06-2011, 09:37 AM
There is a local guy with a cammed, bolt-on C6Z06 that wants to run me in my 2002 Camaro Z28. My Camaro is fully built with a 402ci LS2 motor, TFS 215cnc heads with port work, EPS custom cam, ported fast 90mm intake and NW 90mm tb, 1 7/8 ARH headers, Custom true dual exhaust, th350 tranny with a PTC 5000stall, full suspension, strange 12-bolt rearend with 4.11 gears. 28" Hooiser DR's in the rear with 3.5" skinnies in the front. My car is 3500+lbs with me in it and has ran a best so far of 10.39@129mph at the track. This was the first time I ran the car with the new setup so i'm sure she's got more left in it.
So who will win in a straight up 1/4 mile drag race granted we both hook up good off the line?
Let me hear your thoughts..
Mike Morris
12-06-2011, 12:02 PM
Depends on the driver
The C6 should beat you.
djfury05
12-06-2011, 12:06 PM
If he can drive and the car is running well I'd say your in trouble :(
Travose21
12-06-2011, 01:15 PM
u will win he wont leave with you but ill go out there light as i can be cause he is light with more cubes
