Notices
WTB: Driveshaft for Short Tail TH350 in LS F Body
Old 12-07-2011, 11:46 AM
wg871's Avatar
Default WTB: Driveshaft for Short Tail TH350 in LS F Body
Looking for a driveshaft for a short tail TH350 in a LS F Body, my factory one is too short. Thanks
Old 12-07-2011, 12:23 PM
cyclerage's Avatar
I have a driveshaft that came from an 82 fbody with a 200c(same size as th350)
Old 12-07-2011, 11:18 PM
wg871's Avatar
What is the length of it overall?
Old 12-08-2011, 04:42 PM
wg871's Avatar
Bump ttt
Old 12-10-2011, 01:09 PM
ddr698's Avatar
I have a 2.5" chromoly driveshaft that was used with a stock 10bolt and a th350 (i believe the short tail). It measures 44 & 7/8" center of the u joint to the center of the u-joint. If its what you need let me know by pm as im sure i won't remember to check back...
Old 12-15-2011, 11:12 PM
gearedfather's Avatar
Default d-shaft
i have about 55-60 aluminum driveshafts of different lengths. can you give me a length from center to center on the u-joints. if it helps, your old one is most likely 40-7/8"....
Quick Reply: WTB: Driveshaft for Short Tail TH350 in LS F Body
