Small Block & Big Block Chevy Specific - Locked up 454
View Full Version : Locked up 454
matt01ws6
12-07-2011, 08:46 PM
Ive had a locked up 454 for bout 30 years sitting in my garage now finally building it for my 70 chevelle. But I need to free up the bottom end to tear it down any ideas?
cambirdracing
12-08-2011, 06:59 AM
Depends on where its locked up at! Rings stuck? bearings fried? Just start pulling it apart with a big hammer to get the piston and rods out. You are going to have to replace the rings and bearings anyway.
matt01ws6
12-08-2011, 06:25 PM
Yea I kno I think it's the pistons rusted to the walls I've gt it torn down all the betting and shit in the bottom end are good still.
Big Al
12-20-2011, 04:57 PM
Just "unstuck" a 427. Used brake fluid and ATF about 1/2 and 1/2 in the cylinders. Just wait a while and try to rock it. Then clean the walls with Scotch Brite as the pistons go down. Take your time or you may break a ring land. Just rock it a little at a time.
Al 95 Z28
93Z2871805
12-21-2011, 01:03 AM
Al 95 Z28
I did something like this with my 400 (didn't try the brake fluid trick though), just soaked in ATF, after letting it sit for some time I rocked it loose. Then I hit the walls with oven cleaner and a Scotch Brite after the pistons were knocked out, rinsed the block, then oiled it down. Worked pretty good (then I ended up punching it out to a 406 anyway, lol).
