? about ms4
? about ms4
i got a ms4 cam from a friend and i know the ms4 is a big cam and i know i need spring and all that ....my ? is what heads will work badass with he cam i been asking around but i get a different answer most people say that the l92 from the ls3 will work badass and other say that the 799 and other say that the stock heads will work good soo i dont know ...
Texas Speed has the fastest N/A stock bottem end record and they did it with the MS4 and PRC 215s. You can run the stock heads fine with the MS4 but you'll get more power out of a set of aftermarkets. Just call TSP and tell them what your looking to do and they'll point you in the right direction. Good luck.
We will be closed tomorrow to complete the moving process into our new facility, but will resume normal business hours on Monday. Feel free to give me a call I will be happy to help you with your setup!
what is your current motor and what heads?
And also nearly as important. what is your budget?
For the L92/LS3 rectamgle port heads you'd probably want cam designed specifically or them, not one spec'ed with cathedral ports in mind.
Captain Double Post
op, the ms4 is a great cam, but its not a budget way of going fast, max effort cams need max effort parts, i have ran the ms4 for 2 years now, i think its a great high rpm cam, van , yes the tsp car broke some records with that car, but its a gutted race car set up perfect, there is way more to tsps car than h/c combo.op what are your goals for the car?i would shoot for the prc227 if you could swing it, just make sure tsp knows what cam you have, imo set that cam up with all the other mods it needs and you will love it, it just takes alot to get the most out of he ms4.
when i spoke to matt at tsp about the ms4 for a 383 stroker he said it would depend on the heads and if they could flow it.
I have 241 casting heads that will be getting modified but a good set of aftermarket heads sound like the way to go with this cam, was told by some American's that came to a car show out here in Australia that Trickflow were one of the best you could get.
i'm going a slightly different cam now with similar specs but not as aggressive to suit the 241 cathedral port heads i'll be using. Other wise ms4 or a 244/248 were on the cards and from what iv read with good heads is a very good cam.
ive been running the ms4 a year now love it,not to bad to drive around at all..i made 413wrhp 379ftlbs on a dyno day and the car was only tuned so i could drive it,im running 241 heads milled .010 with a 3angle valve job,and an ls6 intake.This season the heads are getting ported and i will have a fast 90/90 combo and it will be tuned!!!!
yeaa i know its a bad *** cam and im just trying ot built my first car im in the process of geting and trans am ls1 and im just buying parts for it because i know it takes time and money to build it so im starting to buy some thing ..my plans for the car is to hit the 11 or 10 if i can with spray o with outed...thanks u all because i been asking around and in otter pages like rgvtruckperformance and they never reply
Captain Double Post
i think 2200 range ,been awhile since i have been on tsps site, there killer heads though, if you do plan on heads and go with the ms4 make sure you tell them that, im sure they can put a nice package for you together, i love the ms4 and if your hardcore i think you would like it as well, i just always tell new guys to make sure you read up on all the good and bad of a big cam,
Im running the MS3 and trick flow 220s. Had some PRC 243 2.5 heads before. They are around the same price. Do the tricks flow and rocker arm trunnion upgrade. And explain your intentions so heads are setup for your application.
