intake/harness
intake/harness
ok, here is my issue. I have a '01 truck 5.3L engine, I want to put a 98 LS1 intake on it and use the 01 truck harness...question is...will all of these item work together?...also will 01 vette heads work with these parts also?..tks
The truck is probably going to have different plugs for the injectors than what's in the car intake...but they make adapters. It also could be a drive by wire setup...which is ok, just use the truck throttle body on the car intake if that's the case.
The harness may not lay right until you remove some tape and split loom, and just re-think how it's taped.
