Vacuum to low with 224 cam?
I had a scanner on my car after running at the track and noticed that the the car was showing 14.2 of vacuum at idle and 17.9 under a load. Is this to low with a 224 cam or is this an indication of something wrong?
Eric
Eric
Originally Posted by M6HuggerSS
but what problems would low vacum cause?
LS1Tech Administrator
Received 1,489 Likes
Originally Posted by Z28GSXRTim
Back when I had a HUGE cam, if the idle went too low, the brakes barely worked. With 22x cams and low 23x cams, there shouldn't be a problem. The HVAC system works off vacuum (switching between vents, etc.). There are a few more systems, but the brake system is the biggest one.
