questing on cam and nitrous ?
hey guys i just installed a single fogger wet nitrous kit on my car 99 t/a mods are in sig + ss3600 stall and freshly rebuild trans. now im looking to get in to a cam. BUT im not going to be using this motor for long. im planning to build a 370ci lq9 with forged internals. im looking to spray on the 346 a 150 and on the lq9 a 300. i have the NOS big shot kit good for up to 300+ hit.
now i was thinkin about getting a nice size cam for nitrous to put on the 346 and that i can swap out to the 370 ci when i was ready.
in mind for the 370 ci forged pistons and rods. not sure on brands yet. im trying to leave the stock crank should hold up to 900hp if im not mistaken. im on a buget. im getting parts *** i go along. id like to also go with th400 trans brake rever valve body. building this may take me a year, year and a half. i want to go with the victor jr efi manifold. dual plate fogger 150 and 150. i will be doing the roll cage subframe connectors safty loop on the car early next year. stock suspension except for wats listed on sig looking in to going back to stock springs.
whats intreaging for me is choosing the cam on this. i like choppy idle my brother went with 228/228 588/588 112 lsa and i love it i think he should have gone bigger. i know bigger is not always better with a cam thats why im here. the car will be my dd till the new motor is done. after will be weekend and strip car only. would like toi know u guys honest oppinions, sujestions, ect.
thanks in advanced...
i was thinking ms3 or the torquer v3. i seen in couple threads on these about fly cutting. so wasnt sure bout slapping it in. im also looking to swap the cam in to the 370ci. will the ms3 or v3 work well on the 370ci?
SCott5 didnt quite get wat u wrote ???
Captain Double Post
i agree have pat g do your cam, the ms3,4 are proven cams in the right setup but there old school, there is so much better cams out there, you wanna get a cam made for the mods you all ready have done, gears,stall etc. listen call a few sponsers,you will get the best info from them , not saying tech doesnt have good advice but you will get more usable info talking with eps,tsp or another great sponser.
ok, just wanted to get some advice now. to know more or less what i was going to do. i will be spraying the motor as it is right now for a few months. untill i get the roll cage connectors and safty loop in. then ill think about the cam. so my final gole it the 370ci. when i speek to the sponsor what would i tell him im building? i know all or most parts will swap from one motor to another. will it work well on both?
will the cam suggested for the 370ci work well on the 346?
LS1 Tech Administrator
Sorry for the late reply (was busy tuning all weekend). If nitrous performance is more important than NA performance, you need the cam to be more biased to open the exhaust valve earlier. A 370 with stock heads is going to want more overlap than an LS1. The single plane intake is going to want an earlier intake valve open/close and a later exhaust valve open/close. I would be looking at a 234/236 110LSA +2 cam for all motor, but a 300 shot is going to to want the exhaust valve to open 9-10 degrees earlier while keeping the IVO/IVC, EVC and overlap the same as what works best on motor. The resulting nitrous cam would be 234/246 112LSA +4. If you do the math, you'll see that it has the same valve events as the 234/236 110 +2 cam except the exhaust valve opens 9 degrees earlier. This is critical on nitrous because it burns so much faster, you need to open the exhaust valve much earlier to reduce pumping losses. You'll also be retarding your ignition timing 10-12 degrees so all this helps.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
got a quick question. im going to run 100 shot witch is 51N 31F jets on the NOS KIT but they didn't have the 31 so i got a 32 for fuel will i make much of a difference just a tad richer right ? i know lil mistakes on bottle can cause a boom. so any help will be good thanks ...
