fuel pumps. whats everybody running?
Old 12-09-2011, 06:03 AM
96s-10ss's Avatar
Default fuel pumps. whats everybody running?
ok heres my build, 04 GTO 11.5:1 compression, 250hp nitrous 42# injectors, edelbrock vic jr intake, tb elbow, edelbrock fuel rails.
what should I run for a fuel pump? I was thinking twin walbros? maybe there is a better pump for my application? let me know what the best pump for me would be.
Old 12-10-2011, 12:46 PM
RARON455's Avatar
Holley blue,, But I am running a dedicated standalone low pressure system. I have seen the walbro setups in alot of cars though,, seem to work fine, I run a walbro in my tank for the engine, Never had any trouble with it. I have seen other systems, but the price starts getting up there pretty quick.
Old 12-10-2011, 01:07 PM
87silverbullet's Avatar
The Racetronix with a hotwire kit is what most use but you can go with pretty much any 255l pump out there. There is also the Aeromotive Stealth 340 which flows more than a 255l pump.
The walbro is a cheap pump that works. Mightymouse in the FI section has 3 walbro's in his tank and has 1200hp and has gone a best now of 8.50's.
I think Carter01 on here has one in his tank is is hitting a 300 shot off the fuel rail
Here is a link to New Era performance which is one of our sponsors for a Walbro 255 for $99 bucks
Old 12-10-2011, 01:43 PM
dr ls7's Avatar
Magnafuel 500 feeding an Sv1 carb and Holley blue for N2o stand alone system
Old 12-10-2011, 08:32 PM
Cape T/A's Avatar
Im running a racetronix and hotwire kit on a 200 shot. Not sure if that would still support your bump in compression and larger shot, but I think it should.
Old 12-11-2011, 01:05 PM
LS1TECH Sponsor
Racetronix's Avatar
Racetronix is the most popular/proven setup:
F99 Fuel Pump Assembly - Performance
Please read our technical description on why the F99 setup is required for proper fuel system operation.
Racetronix distributes standard Walbro pumps at some of the best prices out there.
These are all Walbro HP models which share the same internal parts with different inlet configurations: (We do not recommend the use of these pumps in a 99-02 module)
GSS342 - 255L/Hr Fuel Pump - High Pressure
GSS340M - 255L/Hr Fuel Pump - High Pressure
GSS294M - 255L/Hr Fuel Pump - High Pressure
NEW!!! Fuel Pump - 386L/Hr, Turbine HP
We stock / manufacture a wide range of wiring solutions, filter socks and installation parts:
Fuel Feed - Tubes - Plastic
Fuel Pump - In-tank Electrical
Fuel Pump Filter Socks
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 12-12-2011, 10:48 AM
blue99fbody's Avatar
i run a walbro 255 w/hotwire in tank and standalone cell up front. 11.7:1 cr on about the same size shot. 522whp na, 770whp n2o
Old 12-13-2011, 01:08 AM
soundengineer's Avatar
Nasty Performance Stage 3 Street kit...
Dual In tank Pump..Pump setup Made By Lonnies Performance
can be set up to use both all the time, or use a single on motor, and the 2nd only when nitrous is armed
also easy to switch which is primary and which is secondary, so you can periodically switch main pumps with wiring to not wear one out before the other.
and he makes it so you can either send in your existing fuel bucket for modification, or you can buy the fuel bucket from him and he sends it to you complete(fuel buckets are not a cheap part by the way)
good up to over 1200 RWHP
Old 12-13-2011, 11:21 AM
Nasty N8's Avatar
Thanks Soundengineer you are correct that is the simplest most reliable system available. Give me a call I can get you setup with the right system for your exact needs.
