HP Tuners Standard version without Wideband
My car was tuned when I got my cam and headers installed, I was never 100% happy with the tune, and always wished I could tweak and change a few things. Since my tune I have done a head swap from my stock 806 heads to 243's and I am about to install a yank ss 3200 stall so I know it will be time for a re-tune.
Since we are picking our own christmas gifts this year, I was looking at possibly getting the HP Tuner's standard edition without the wideband, would I be able to make the proper adjustments without the wideband for my new mods, or would I be wasting my money? I never have liked being dependent on somebody else to tune my car.
I don't know a whole lot about tuning yet, but willing to read and learn.
You can always run the wideband separate, or give it an input like the EGR solenoid. I am sure that write up is either on here or HP Tuners forum on how to do that.
You can do anything you want with the standard version, since normally the wideband is used only for WOT stuff. I believe it is ALOT safer and more controlled to do the WOT tuning on a dyno. You will get the best graph from it. Normally any shop with a dyno will have a wideband input with it, so I would use that then you can change it via RPM or MPH in your tune file, whichever they have mapped out.
Plus it is alot easier to help people when they can post up any relative scans and tune files to get on the right track.
I would do it.
I would do it.
It would be a better idea not to too much, but it depends on what AFR your car was running at before. Most likely the AFR will not have changed THAT much to be ok at WOT, but its always better to be safe than sorry.
It entirely depends on what AFR you were running at before.
Lean Is hot. To lean you will need a new engine. If you add airflow you will go lean. The fuel trim factors will help. I do not understand people to spend the money to make there faster and then cheap out on a tune. Get HPT with the WB input and a wide band. It can save you big bucks in the end. One year I saw 4 engine on the floor for being to lean.
Dont even think about tuning your own car unless your ready to invest in the following...
Hp Tuners Pro
Wideband
www.TheTuningSchool.com (Beginner/Advanced Learn at Home Coarse)
Why?
Because most people who buy Hp Tuners get frustrated after the 1st month realizing that stickies and google searches are not going to teach you how to fully understand how to tune a car.
Trust me, I spent a year chasing down "How/What/Why/When" before I finally gave in more $'s investing in real results.
Wideband/Tuning Classes = Best investment I ever made!
Hp Tuners Pro
Wideband
Why?
But using the standard version will get you where you need to be so you can be safe and run a wideband on the dyno. IMO its NOT safe to be running 100+ MPH on the street just trying to dial in afr for WOT.
You don't have to buy a wide band to tune your own car.
You can go to a dyno and use their wide band. Also, you will be tuning to know where your ACTUAL peak torque occurs and not just where you THINK it occurs.
You can also tune with out a wide band at all, if you tune using your knock sensors. I would not recommend someone in your shoes doing this though.
It is a tad easier to tune with the Pro and a Wideband input, but you can get your standard upgraded to pro for about $279 later on if you want. Using the pro to tune with a wideband requires quite a bit more learning than just using a dyno and its wideband.
A wideband is only $250.
Reading plugs and relying on KR is reactive, not proactive.
Pay to play.
One way (noob uses recommended sensor) or another (noob with blown engine).
Stupid is as stupid does...
"Hey Jimmy, just wave your hand when you hear knock and tell me how loud it is. If it just barely there, we will just take a degree out and square up the jets!"
You do realize that not all EFI vehicles came with knock sensors right?
