2800 stall with ms4??????
Old 12-10-2011, 03:04 PM
831jd's Avatar
Default 2800 stall with ms4??????
hi guys i had a quick question i know a 2800 stall is really small for a ms4 cam on a ls1... but would it be able to at least get the car rolling be able to start the car.... without any problems? car has full bolt ons and 4.10s will be getting a bigger stall later... just trying to get things running for now... thanks
Old 12-10-2011, 03:51 PM
Cam72aro's Avatar
yes, the car will run. You can run a giant cam with a stock converter. Its not gonna be ideal and get the most out of the cam, but it will still run.
Old 12-10-2011, 08:37 PM
garygnu's Avatar
did you buy the cam ?
Old 12-10-2011, 10:59 PM
01ssreda4's Avatar
It will get you by and that's about it.
Old 12-11-2011, 10:21 AM
blk/slvr02ss's Avatar
U should b fine w/ that stall & 4:10's !
Old 12-11-2011, 11:16 AM
831jd's Avatar
yea i got it really cheap from a friend that had it in his car but now
his doing his turbo build..
Old 12-14-2011, 08:21 PM
projectX's Avatar
Plan on swapping soon if you are gonna race that thing.
Old 12-14-2011, 08:49 PM
Sales1@Texas-speed's Avatar
Definitely plan to swap that converter out. It will be drivable but like others have said it will be less than ideal for the MS4.
Old 12-15-2011, 08:14 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
You definately neeed to change the converter with the ms4.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Quick Reply: 2800 stall with ms4??????
