Stereo & Electronics - Monsoon Question
Nowhereman
12-11-2011, 12:45 PM
For sometime now I have had the display on my HU not light up.
I just looked at it with some reflective light and noticed that it is still functional, counting down tunes and showing the time.
It just isn't lighting up.
Is it possible that it has a backlight problem?
Maybe I don't need to replace the display itself..
Here are some threads about Monsoon Display and Lighting issues:
http://www.ls1tech.com/forums/showthread.php?t=113734&highlight=monsoon+led
http://www.ls1tech.com/forums/showthread.php?t=478017&highlight=monsoon+display
http://www.ls1tech.com/forums/showthread.php?t=396085&highlight=monsoon+display
http://www.ls1tech.com/forums/showthread.php?t=388963&highlight=monsoon+display
http://www.ls1tech.com/forums/showthread.php?t=404470&highlight=monsoon+display
http://www.ls1tech.com/forums/showthread.php?t=314857&highlight=monsoon+display
http://www.ls1tech.com/forums/showthread.php?t=214463&highlight=monsoon+display
Basically it could be 2 issues: a) the bulb blew or b) the solder on the screen's contacts needs to be re-flowed because it has cracked.
Since the display appears to work but just isn't lit, its probably a blown bulb.
If it was a solder problem, the display would appear garbled.
Nowhereman
12-11-2011, 09:50 PM
If cold solder joints are the problem, It's as good as fixed.
Ill tear into the HU on Tuesday.
Thanks.
JOHNNY59
12-13-2011, 09:14 PM
replace the bulb.
aquariussuperman
12-13-2011, 09:51 PM
Replace the entire Monsoon unit with a double DIN and don't look back?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
