Gen 5 Camaro Drivetrain Tech - 35 Spline Spools available from Gforce Engineering
Gforce Engineering
12-11-2011, 01:02 PM
Hey guys,
We here at Gforce Engineering are always looking for ways to bring new innovative and exciting products to market.
We teamed up with Strange Engineering to make 35 spline spools for the 2010+ Camaro back when they first came out. We threw them on the shelf and never did advertise them much because we just got busy with other projects.
It's now time to start letting people know they can build the factory rear to hold big power using our spools and matching 35 spline inner stubs.
We designed the spool to use a 35 spline stub. The factory diff is a smaller 32 spline, the big 35 spline stubs dwarf the 32 spline stubs in size.
We have a shelf full of them and we now think it's time to start offering them to the guys wanting to build a really strong rear using the stock Camaro housing.
For those not familiar with a spool, it replaces the factory posi unit with a solid one piece carrier that the gear bolts onto.
They are very strong and will hold some really serious power.
Best of all they are cheap.
You get some tire squeal going around corners and the car WILL act different with a spool but it's easy to get used to. Some say a spool is not for the street but many people drive them on the street with no problems.
I wouldn’t recommend one in a daily driven car but a weekend warrior or drag only car would be the perfect candidate.
We will be offering our Spools with axles and stubs made to fit the spools for a package deal starting at $1569.
If you already have our axles then all you would need to do is buy the spool and the inner bolt on stubs for about $750.
Let me know what kind of interest you all have in this set up.
Thanks
Chris
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/2010CAMAROSPOOL-1.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/2010CAMAROSPOOL.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Blackaxleends.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Blackaxles.jpg
