is this grounds for a rebuild
i just bought a running 4.8 with trans for 1100. ran grate but i removed the 709 heads to port and polish when i found this ugly sight. i was planing on changing the crank to make it a 5.3 but if i also need a rebuild might as well get ls6 pistions. but if i dont have to i wont. the cylinder walls look clean but piston head are coated with the flacky black stuff
that is grounds for some serious cleaning i'd say. Honestly, if you have the engine out and the top end tore off, why not go ahead and refresh it; new rings, arp rod bolts, make sure the bearings are all good, etc..
Build it, run it, blow it...then spend $700 and do it all over again!
