carb conversion kit
This has been answered here many times before....but to summarize, it's usually cheaper to go with fuel injection. To go carb'd, you'll need a control box from MSD (i think it's roughly $650), intake (roughly $350-$500), Carb ($300-$700, depending on what you want).
I'm betting that you'll be able to run truck-style injection in your Monte, and save a ton of $$$ since most engines from yards come with just about everything you'll need....minus wiring and pcm. The biggest concern will be hood clearance.
If you have your heart set on going carb'd, I say go for it. If you're thinking that it will be cheaper, think again. If you're thinking it will be easier, it usually isn't. If you're intimidated by fuel injection, don't be....it's easy to wire up, and there are plenty of answers here on this site.
Whichever way you choose to go, best of luck to ya
Welcome to the site!
Prices for the MSD box and intake are a bit high there, bub. The kit with both can be had for about $700 at various retailers.
If you broke it down due to budget constraints, or if you aren't on a tight schedule, you can find deals here in the classifieds. I saved about $175, but the intake (Victor Jr) took a while to find, hawking the ads every day.
I stand corrected on pricing...but you're failing to mention the price of a carb. If you have to source a new one, you're easily over $1k for the setup. That's my point .....it's rarely less expensive than injecton unless you are going with used parts, or happen to already have a carb lying around.
I would go efi in a late model application where a complete fuel system upgrade wouldn't be required using mostly used parts purchased off the forum here or ebay, etc.
For an older car, I'd go with a carb in a minute. For my L92 head/LS2 going into a 61 BelAir - - $310 for the MSD controller, $275 for the Victor L92 intake, already have a carb, but a basic & versatile Holley 3310 - 750cfm can be picked up for under $100 usually. Even with a new carb kit that's under $700.00.
Start adding up prices for injection parts without them being used, and new carb parts look cheap again. Personally, it would depend on the vehicle for me:
It all comes down to what you want, but it can be done pretty cheaply.
Regardless of how you get the stuff. IMO DO NOT BUY THE Edelbrock KIT. Buy the MSD 6010, Whatever manifold you want and a properly sized carb. The edelbrock box is a POS IMHO. Go for the MSD with the adjustable timing, rev limiter, timing retard and other capabilities.
X2 on the comment about buying the kit vs. buying the manifold and msd seperate...do yourself a favor and buy the intake seperate, then buy the msd 6ls....you will be able to dial in different tunes depending on if you r cruising or drag racing because the 6ls incorporates a map sensor so you can tuine in your vacuum advance. This would be way better than leaving all the enigne tuning up to a "pill". Good luck man...im doing the same thing in an 81 camaro!
60, 87, carb, carburetor, carlo, conversion, converting, edelbrock, engine, fuel, injectioin, intake, kit, kits, lq9, ls2, monte
