my 98 v6 camaro
MASS seller approved
my 98 v6 camaro
i have a 98 camaro v6 picked it up cheap body is perfect doors shut excellent never been hit , i want to make it a 6.0 t56 car i might be able to pickup a 2000 5.7 t56 harness and ecm , is that a good place to start ? i woud have to give up my 6.0 4l80e harness and ecm from my 03 savanna.
first thing is we are both using ls6 intake can i just repin stock injector plugs or get adaptors? map sensor extension harness will also be needed for him to use my truck harness (one main reason he can use harness is he is running a 4l80e i sold him) if he uses camaro harnesss he is only going to mod it for his 6.0 4l80e swap into 96 impala ss . should i try to get the harness or not go through all this trouble or can i steer clear of all stock harnesses since im running a t56? help please
http://www.lt1swap.com/2000harness.htm
Ls6 intake+ Truck harness= ev1 injector plugs. Not hard to install. Use heat shrink in splices.
Harness isn't that hard to work and this site has a good walk thru.
I gave around 30 for my injector plugs.
If you go t-56 make sure the 6.0 has the short crank, I think 01+ models if not you'll have to use a different crank or get that one worked.
thanks for the link alot of good info... i missed out on the stock camaro harness so i am going to be running the truck harness for now and yes i do have the shorter crank 6.0 but i think i might have to sell it anyway not sure yet again thanks for the info
