LT1 355 for sale
LT1 355 for sale
Category: Engine - Complete Motors
Price: $3500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): DE
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Engines Block etc
355 LT1 block bored .030 with 2 bolt mains 11.5:1 compression
JE .030 Nitrous pistons with plasma moly rings
Eagle H-beam 5.7" rods
Stock crank polished and chamferred externally balanced turned .010 under
ARP main cap bolts
LT4 balancer
ARP head bolts Felpro 1074 head gaskets
High pressure oil pump with stock LT1 oil pan
Comp Cam R-lifters
AFR Hydra Rev kit
Heads, Cam, Intake
GTP Stage 2 ported LT4 heads with matching intake 2.02 1.6 ferrara valves flow
296 205 @ .600 205cc intake runner
Intake fully ported and set up for a 58mm throttle body
Comp Cam stud girdle with integrated valve covers
Comp Cam pro magnum 1.6 roller rockers
GTP-6 matching cam 235/242@.050 .56x .59x 112lsa- billet core
Additional parts
Arizona Speed and Marine 58mm billet throttle body
36lb injectors
CSI electric water pump
MSD 8.5 ignition wire
95 knock sensore
New GM optispark with less than 400 miles
Custom 95 PCM with dyno tune for combo
NX SHO single nozzle nitrous kit with upgraded pro power solenoids
NX purge kit with feed etc
Trick flow intake elbow with custom welded bung for nitrous nozzle for direct shot into intake
Combo has approximately 3k on it
Made 383rwhp through th400 N/A and 535rwhp on 150 shot
11.4@118 with 1.57 60 ft N/a, 4.11's and 26" tire
10.35@129.19 with 1.47 60 ft on a 150 shot, 3.73's and 28" tire
10.2@134 with 1.59 on shakedown pass with 200 shot, 3.73's and 28" tire
The above was at 3650lbs raceweight
Combo is setup for pump gas
I'm asking $3500 obo
I live in Middletown, Delaware
