L@@K****NEW - MWC Fab 9" rearend - NEW - Midwest Chassis Fabbed 9" rear end****
Category: Accessories
Price: $4000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NJ
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
For 1993-2002 Fbody application.
This is a fully loaded optioned rear with all the goodies!!!
Besides waiting for like 2 months
this rear will also set you back 5K
Eric at MWC is the premier builder of 9" rearends and I can't say enough about his attention to detail, like brake line holders, ring and pinion gear setting, his welding, the use of the best materials and hardware thru out.
No one builds a better rear than MWC.
Here are the specs and also what is included.
Rearend is narrowed, 3" per side and comes with MWC torque arm,
MWC safety loop, set up for MWC Watts link
Large fill cap
Tow loops
Tapered housing back brace
Powder coating
CM Panhard bar
CM LCA set
new GM backing plates
3 channel ABS modification
Richmond Gear upgrade
3.50 gear ratio
Wavetrac 35 Spline Differential upgrade (lifetime warranty)
Strange aluminum case, pro support,
CM billet 1350 yoke
HD 1/2" wheel studs,
axles are also set up for MM factory press in studs
