LS3 Maloo stock engine how much nitrous
Hello from down under
i have decided to give my new ls3 gxp maloo ute a spray of gas
its basicly a G8 but a ute its a a6 car with 3.3 diff gears
i currently run a 12.8 -109mph 1/4 mile with only a dual 3 inch exhuast, stock headers, stock Cats, and Intake
i have a dual stage plate setup and was thinking of spraying 75hp 1st stage 3000rpm and a 100hp 2nd stage 3500-4000 rpm, i will be getting the car tuned mafless and to suit nitrous before i spray
will this be ok?? i will upgrade fuel pump if need be and ill run a NOS dual stage wot window switch and a fuel pressure switch
bottle heater ect
also hiflow cats
my question is will a total 175hp be to much for a stock bottom end ls3??
i know plenty of guys here are spraying a lot more on ls1 so i think it will be
and also what sort of gain will i make in the 1/4 with this size car weight around 3850lbs car
thanks in advance
Dusto
bottle heater ect
also hiflow cats
thanks in advance
Dusto
bottle heater ect
also hiflow cats
thanks in advance
Dusto
bottle heater ect
also hiflow cats
thanks in advance
Dusto
That sounds promising I have had nitrous car before but no ls motors previous was a 3.8 Buick v6 which I sprayed about 20 bottles at 150 to 175 into with all the right saftey gear just want to make sure the high comp ls3 pistons and rods will be up for the task
