Alkycontrol Meth Injection System - Complete
Category: Accessories
Price: $425
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
Kit includes the following:
- Progressive controller
- On/Off/Gain/test control box
- Cat-5 connectitivity between the 2 boxes
- 250GPH pump with protective sleeve, 6AN inlet and 4AN outlet fittings
- GM 3-bar MAP sensor
- 5V regulator - converts 12V to 5V for the MAP sensor so you do not need to have a 5V power source
- Turn-on LED indicator - LED turns red when pump is activated and then green when pump goes over 50psi
- Nicely-crafted 2-gal stainless tank with mounting tabs, 6AN outlet fitting, and vent with shut-off valve
- 6AN braided SS, teflon-lined from tank to pump
- 14' 4AN braided SS, teflon-lined feed line. I had it trunk-mounted but the line can be shortened to suit for your setup
- Brass filter and check-valve assembly
- 4AN braided SS, teflon-lined feed line from check-valve to Y
- 4AN Y with dual-nozzle assembly that was fitted on a 3" intercooler pipe
- 3 nozzles included: (2) M10 and an M15
Pump and control boxes were recently returned to Alkycontrol for a checkup. Julio will vouch for this system.
$425 (firm) shipped to continental USA
