Torque seems low? 4.8 mpt70 509/452 @12psi
Anyone have some insight on why my torque number seem low? Most of the similar combos I see have equal or more TQ than HP. I have spent a lot of time tuning N/A cars but not much with FI. Any info would be great!
Here are some details:
08 LY2 4.8 9.2CR, stock long block, 243 heads
LS6 cam/springs
LS2 intake
80lb injectors
4L80e with FTI3600
front mount mpt70
14* of timing
11.5 AFR
93 pump gas
TR6 plugs
eBay IC
3" IC piping
88mm truck TB
Precision 46mm WG
LS3 MAF
E38/T42 tuned with EFILive. Currently a MAF only tune, no trims, 2bar VVE tables are sane in case of MAF failure.
Any ideas?
In addition... how much boost do you think I can run on 93 pump?
thanks,
David
LS6 cam/springs
LS2 intake
80lb injectors
4L80e with FTI3600
front mount mpt70
14* of timing
11.5 AFR
93 pump gas
TR6 plugs
eBay IC
3" IC piping
88mm truck TB
Precision 46mm WG
LS3 MAF
Any ideas?
thanks,
David
thanks guys... we were commanding the TC to be locked but it was unlocking (it looked like a downshift on the dyno chart). Its an issue with the 4L80e OS on the T42 controller.
thanks,
David
