LS3 block + LS3 pistons + 5.3 crank and rods = LS3?
Old 12-15-2011, 03:36 PM
StanIROCZ's Avatar
Default LS3 block + LS3 pistons + 5.3 crank and rods = LS3?
I have a 2005 aluminum 5.3 with 30k miles that has water damage in the bores. Being a 2005 model it has the floating pin ‘beefy’ rods yet is still Gen III 24x etc. I’ve considered punching it out to 5.7 but it seems too risky since no one can give a definitive answer on whether or not it is safe to do. But the rotating parts in this engine are extremely clean.
I can get a LS3 block for $1600 shipped to my door, and I can get take out stock LS3 pistons. Tell me why I shouldn’t use my 5.3 rods and crank to build an LS3 short block? I’ll be using it with Gen III electronics in a road race built 3rd gen Camaro.
Stuff I’ll need from Machine Shop
-Balancing: The 5.3 crank will need balanced for the heavier slugs – I assume they’ll have to add weight. How expensive is it to add Mallory?
-Pistons installed to rods, or I could do this at home since they are floating but it’d be nice to have a tool for it
-Cam bearings will need installed by machine shop.
Parts I have:
-5.3 crank and floating pin rods
-oil pump, 2x timing gear, and rear cover from my low mile 5.3.
-cathedral port 799 heads with some porting and chamber work. Compression will be high, I figure 11.2-11.3. Is this too high for 93 octane?
-the rest of the top end from an LS1
-224/224 0.588/0.588 112 Comp Cam, push rods, and 1518’s but considering something bigger
-New LS2 timing chain
-LS1 balancer but considering investing in a ATI or similar
Additional Parts needed:
-water and oil plugs for the bare block
-New rod and main bearings
-new GM rod bolts? Or is that only a Gen III thing?
-head gaskets
-Gen IV front cover and cam sensor
-Gen IV valley cover to block off DOD ports
-extension harnesses for knock and cam sensors
-12588670 LS2/LS3 Black Timing Chain Tensioner
It’s looking like I’ll have $2200 into the short block and ~$200 for used covers + wiring extensions.
Bad or good idea? What am I forgetting? If anyone else has done this here please refer me to the thread.
Thanks!
Old 12-15-2011, 04:03 PM
moge11's Avatar
sounds like the best way to go...do it!
Old 12-15-2011, 04:18 PM
KCS
Moderator
KCS's Avatar
I used an LS1 crank with LS3 rods and pistons. It cost $230 with two small slugs in the front and rear counterweights.
Have the machine shop pin fit the rods and pistons. I measured about .0005" on mine, and IMO, that is too tight. I ended up honing them to about .001".
Old 12-15-2011, 04:30 PM
StanIROCZ's Avatar
Everything else go ok with that build? Was it a new block?
Old 12-15-2011, 05:16 PM
KCS
Moderator
KCS's Avatar
It's actually a seasoned iron 6.0l block. The shortblock went together smoothly, I just have to finish the heads and intake and I should have it running by the first week of January.
Old 12-15-2011, 09:03 PM
redtan's Avatar
If you're buying the LS3 shortblock already assembled, then why are you taking it all apart and putting in the different parts? What's wrong with the LS3 rotating assembly? Are you getting just the block? Are you getting the shortblock with busted rotating assembly?
Old 12-15-2011, 09:06 PM
StanIROCZ's Avatar
I'm buying a bare LS3 block.
Old 12-15-2011, 09:11 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Parts I have:
-head gaskets
Thanks!
if your getting rid of the aluminum 5.3 block, pm me the price you would want for it
Old 12-16-2011, 06:56 PM
blkbird2kta's Avatar
I have a complete l92 shortblock with a cracked crank. Its going up for sale for $1000. Pm me for info.
Old 12-18-2011, 01:24 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i just need the block...
Old 12-18-2011, 10:36 AM
COPO9560's Avatar
For $2200 ERL can dry sleeve your 5.3 block and give you a 4.125 or larger bore. This includes all machining and ARP main studs. If you plan any machine work on the new block, (cam bearings, check line bore, ARP studs, hone etc) the cost would be very close. Your block with sleeves would be larger and stronger than a stock block.
You can install floating pins at home - be careful to get locks right. I'd check with your shop on the balance cost - might be less expensive to find another crank that requires less metal to balance - on older engines adding Mallory metal was very expensive.
Old 12-18-2011, 11:18 AM
I was referring to the op. Hes buying a block only. I have a short block for cheaper. Just figured i could save him a little money.
Old 12-18-2011, 08:18 PM
StanIROCZ's Avatar
So it turns out that my brand new take-out pistons are actually LS2's, not LS3's, so my buisiness case for this build is dead. So I bought another junk yard L33 engine and I'm going to run the crap out of it for a couple years before I build something. Suppose I could build an LS2 instead, but if I'm buying a brand new block it will be an LS3.
Old 12-18-2011, 11:30 PM
StanIROCZ's Avatar
The LS2 pistons are for sale in the classified section.
Quick Reply: LS3 block + LS3 pistons + 5.3 crank and rods = LS3?
